Conversion problem of blank project to responsive project with Adobe Captivate 2017
  • September 15, 2017
  • 183 views
Hello
I'm working in a school that's producing  e-learning materials for supporting  students learning.  As I watched at tutorials, I "saved as responsive project" my blank projects that I have been prepared at captivate 9.  Than I published my "saved differently project" for devices.  However, in the published folder there is always a .swf document, because of that mobile devices do not support my documents.  How can I convert my blank projects to responsive project properly ?
Thank for your kindest help
Have a nice day
Screen Shot 2017-09-15 at 14.50.04
    Lilybiri
    Conversion is not a one-step work flow (as maybe the marketing people try to tell). You'll get a responsive project, within a Fluid Boxes work flow, but then the work will start. You have to take out all objects that are not compatible with responsive projects (look at the HTML5 tracker). You will have to set up Fluid Boxes. Since the normal fluid boxes (exception is a static fluid box) do not support a number of objects, do not support groups, nor objects stacked in the same location (even when they don't appear at the same moment), you'll have to take care of those before setting up the Fluid boxes and moving the objects in the Fluid boxes. If you had videos in FLV format you'll have to recode them to MP4 video. Just a short description of the work to be done. Don't forget the testing as well.
    armanalirAuthor
    Thkan you for your suggestions, I'll try them.
