Rumbalotte
Feb 27, 2020 5:33 PM UTC
Problem with Audio (slow and deep)
I have a speaker in a file. These are audios. From time to time the files end up getting slower and deeper. Not every time, but every now and then.
Okay, I admit it's funny too. It's spooky and fun. But of course you don't want that.
Eric Dumas
Feb 27, 2020 10:41 PM UTC
can you confirm the version of the software and operating system you are using?
Also, can you confirm that all audio files sound ok when listenig to them outside of Captivate? Can you share a screenshot of the settings you are using to export/preview your file?
Rumbalotte
Feb 28, 2020 1:04 PM UTC
I'm using CP2019, Win10 (64Bit).
This is really strange!
I have now found out that it is in the audio files. But not in the original, which I imported. Apparently it was created by inserting a second of silence. I did that in Captivate. Very strange. does anyone know the problem?
Lilybiri
Feb 28, 2020 1:13 PM UTC
Are the original files in WAV format or another format?
I rarely will use Captivate to edit audio files, but in those situations I never experienced what you tell. Just FYI I always edit audio files with Audition.
