mandar agavekar
Problem with Click box "Disable click Sound" setting
  • August 21, 2017
  • 885 views
I have created a project in Captivate 9. It has approx. 350 slides. I have captured 7 simulations and merged them in 1 file. After publishing the project I noticed that the click sound of the click box is not audible on some slides. I have unchecked the “Disable Click Sound” dialogue box for each slide. Still, the click sound does not appear for some slides. Moreover, the behaviour is not consistent. Sometimes, the click sound for an element in a simulation screen works, and sometimes it does not work for the same element on the same screen. The output is HTML5 and we are viewing it in Internet Explorer 11.
Lilybiri
Which exact version of 9 are you using, please? If it is not the latest, please upgrade to  9.0.2.437. There were some bugs with previous releases.
papaintegrator
Hi Mandar,
Can you check and make sure the project does not have any 'unused items' in it. You can delete them by going into Library > Unused Items (icon) > Delete (icon)
Republish after this and check in IE /Chrome.
/best
Lilybiri
AFAIK deleting unused objects in the Library only affects the raw cptx file, not the published output. Could you explain why this has changed?
papaintegrator
If there are problems in Cptx, same will persist in the output.
