Problems using right-mouse click functionality in a Captivate added to Articulate?
  • July 20, 2010
  • 591 views
Has anyone experienced any problems using the right-mouse click functionality? It's working fine when I preview the project, or view the published Captivate SWF or HTML file, but it's not working when I insert the published Flash file into Articulate and then try it in the published Articulate. I'm using AS2 and Flash Player v10. When I try to right-click it's bringing up the Flash Settings menu you can click on. I've been into my Flash Manager and told it to always allow content from the folder my Articulate is in but that hasn't made any difference. I'm viewing the Articulate on my C drive and I have read that that can cause problems - does anyone have any ideas? If I left-click it recognises it as a click but doesn't recognise it as the correct click action, so just keeps on bringing up my failure caption and won't allow me to progress.
Thank you!
    Lilybiri
    The right-click functionality in Captivate is 'in' the JS-file, that is called by the HTML-file that will open the SWF. But if you insert the SWF-file in Presenter (Articulate or Adobe) the right-click functionality will not be there, because you are not using the JS-file. BTW: this was also explained in the thread where you posted this same question before. Please, do not post the same question in 2 different threads
    Lilybiri
