draysorrill
Zoom H1 records audio in Audition but will not record directly into Captivate CC.
  • August 7, 2016
  • 1375 views
It is set as default in the preferences with good sound level.  It will record to Audition CC: Preferences WAV, 16 bit,  Stereo, 41KHz, volume level set on computer correctly on computer.  But it won't even test calibrate in Captivate CC 2015,
.. anyone had this challenge?
Lilybiri
There is no Captivate CC at all, Captivate has never been part of the Creative Cloud.
Which version of Captivate and Audition are you using: exact version numbers, please!
draysorrill
Yes, sorry, was in too much of a hurry.  I am using Captivate 9.0 v.9.0.1.320  and Audition CC 2015.2  Thank you for your response.
Deb Sorrill - California Biodiversity Instruction
Paul Wilson CTDP
What I do when I have a new microphone that I intend to use with Captivate is to press Shift + F8 to get into the Preferences window. From there I navigate to Recording / Settings and make sure that Narration is checked off. Click the Audio Settings button to reveal this window:
Because my laptop also has a built in microphone it's displayed in the Select drop down selection box. Make sure you have the correct Audio Input Device selected before clicking on Calibrate Input.
Paul Wilson, CTDP
