Jan 10, 2014 6:25 AM UTC
Best VOIP audio settings - problems with participants hearing each other
Hi everyone. I have searched around a bit but can't seem to find recommendations on the very best settings in Adobe Connect (and/or recommendations on server location) to get the best possible VOIP experience for participants.
While little dropouts in VOIP audio occur (and can be expected when participants leave email open in the background and the internet gets congensted for a second etc...) we fairly regularly have the problem that participants on VOIP cannot hear each other well.
For example, today I hosted a session in Brisbane, Australia. I could hear two participants - one in Sydney and one in Perth - quite clearly. But they could barely hear each other. This happens quite a bit - I am loud a clear to the participants as the host and presenter, but they often struggle to hear when I unmute a training participant to ask me a question via audio - I often end up having to repeat what they said to all the other participants.
Any tips on how we can strengthen the VOIP audio between participants themselves? This is especially important when we want to use break-out rooms. Break-outs work great when everyone is on the phone, but when the group is on VOIP, often participants complain that they couldn't hear each other very well in their breakouts.
I have already had participants run the Audio Set Up Wizard, close software and use a headset - all the basics are covered. And, besides, I can hear them loud and clear. Its the participant to participant audio which is the problem. Any tips on which settings to have in the Preferences box or anything else we could be doing would be great.
Many thanks,
Dave
Abhinav_Arora
Jan 13, 2014 6:26 AM UTC
Hi Dave
Could you try using VoIP with Speex Codec enabled in the preferences->Microphone option. The problem faced by your attendees seems to be a bandwidth issue. Speex codec consumes lesser bandwidth. Please try that once in your meetings and let us know if that helped
Thank you
Abhinav
Jan 13, 2014 10:05 AM UTC
Thanks Abhinav. I often wondered what the Speex codec did.
So I assume that...
(a) Only I have to change that setting in Preferences as the Host - participants don't need to do anything from their end?
(b) That the lowest bandwidth of all must therefore be Speex codec set to Fast?
Should I also disable "Use Enhance Audio". The note when I hover over that setting says "Disable if you have trouble with your audio". Will disabling "Use Enhance Audio" further reduce bandwidth usage?
Appreciate your further thoughts.
Dave.
Abhinav_Arora
Jan 13, 2014 4:07 PM UTC
Hi Dave
Yes you are right. You only have to enable the Speex Codec as a host and set it to fast. I can not guarantee this will work for you but it is worth giving a shot as your issue seems to be a bandwidth issue. Also you should not disable Enhanced Audio. Moreover Enhanced Audio is a personal setting for all users and is "On" by default to give the best performance.
Try using Speex codec and do let me know if you find any improvements
Thank you
Abhinav
