Sep 25, 2018 7:59 AM UTC
Is there a big difference in transmission speed between 720p and 1080p Logicool?
Hello! I’m a Adobe Connect user and I have a question regarding a camera.
Currently I’m using a Logicool with 720 pixel and there is nothing wrong with the transmission speed with my pc.
But I’m thinking about buying a 1080-pixel Logicool and I wonder if the transmission speed is too slow compared to the 720-pixel one.
So could you tell me if there is a big difference in speed between the two please?
    Thomas Gunter-Kremers
    Sep 25, 2018 2:47 PM UTC
    There will be no difference because Adobe doesn't support 1080p so you wouldn't broadcast at 1080p.
    Sep 25, 2018 3:04 PM UTC
    Thank you for your comment Mr. Gunter-Kremers.
    Does that mean 1080p cannot send the film or picture it is taking to a pc screen?
    Conversely, could you tell me what pixel Adobe can handle, please?
    Hikaru
