Grey texture showing when using opacity map
  • October 24, 2023
  • 1077 views
After watching numurois video tutorials, i still seem to be getting the same outcome. When adding the opacity map, i seem to get this weird grey showing up where it should be fully translucent.
Textures were done in Marvelous Designer and imported over.
Cyril Dellenbach
Hi Chris,
Are you using a shader compatible with an Opacity map? Could you detail your workflow?
Let me know.
Cyril Dellenbach (Micro) | QA Support Artist | Adobe
CStenwayAuthor
I'm using pbr-metal-rough-with-alpha-blending
opacity map is placed on a fill layer with base colour texture applied, and opacity map in opacity.
Not sure if the image attached is any help with how i set things up.
Thanks.
CStenwayAuthor
The image attached helped indeed. Would you mind sending me the .SPP file? This way, I'd be able to take a closer look at the issue. If not, you can send it to cdellenbach@adobe.com
Best regards,
Sure thing, i'll get the file sent over to the email.
Thank you!
