Jun 13, 2022 2:20 PM UTC
Parts of mesh turning dark grey
Parts of my models are turning dark grey after baking the mesh. Consequently, the textures appear darker then the rest of the scene. What can I do to fix this?
Jun 14, 2022 1:31 AM UTC
Jun 15, 2022 8:05 PM UTC
Check that the faces are not inverted on either model.
I've gotten similar before and flipping the faces on the dark area on the baking model fixed it.
Apr 12, 2023 5:34 AM UTC
how do I check or fix the faces that are inverted because I am having the same issue and then when I put material on the mesh some parts are darker than others
