Some problem with baking Ambient occlusion
  • July 21, 2023
  • 238 views
Help, please! I can't bake the map ao.
Cyril Dellenbach
Hello @Khannyks31211220hmni,
Would you mind sending me your project, so I may investigate a bit more? You can send it to me privately at cdellenbach@adobe.com
Let me know,
Cyril Dellenbach (Micro) | Product Manager | Substance Painter
Hello, thank you for replied. Fortunately, I solved the problem
davescm
@Khannyks31211220hmni What was the problem? Your answer may help others.
Dave
