Making accurate Curved Fuselage Panels for foam remote control model planes using dimension
- 2 replies
- 414 views
- Translate
am a newbie to this community and a beginner with dimension so be gentle!
I am trying to find a way using dimension to create the 2d cut out shapes that can then be curved to make fuselage panels.
I have found some already made ones with cut out formers included but they aren’t very accurate when scaled up
https://ftforumx2.s3.amazonaws.com/2019/09/251948_ca68849575ab5a0ffb6b20f7ddba2836.pdf
Using 3D drawings
https://www.the-blueprints.com/blueprints/ww2planes/ww2-yakovlev/46750/view/yakovlev_yak-3/
I can make accurate formers and using the elevation plans I know the overall dimensions of these pieces.
so is it possible using dimension to make the 2d shapes that can then be bent to make the fuselage pieces?
Can anyone help or point me to a thread where someone has done this already
Thanks in advance
Topics
