Apr 2, 2018 8:37 PM UTC
Greater Than/Less Than/Greater Than or Equal To/Less Than or Equal To Symbols
In FrameMaker 12, how do you type greater than/less than/greater than or equal to/less than or equal to? For example, how would you type "less than or equal to 3" with symbols instead of words? Right now, my workaround is to create a new equation, pick what I want from the Relations group, and then drag the border of the equation box in until it covers the question mark on the left side of the equation.
Barb Binder
Barb BinderCorrect answer
Apr 3, 2018 3:42 PM UTC
Hi Cameo:
I just tested it and got the same result. The less than or equal to works, but I got a square for greater than or equal to.
So... there are two ways to get these symbols: the FrameMaker shortcut and entering an ANSI code. Not sure it there is an error in my shortcut book, or if things have changed—it's from May 1995.
But switching to the ANSI code still works as expected. Hold the Alt key down with your left hand, and type 0179 on the numeric keypad on your keyboard—not the numbers at the top of the keyboard—and then release the ALT key. (For symmetry, Alt+0163 is less than or equal to).
~Barb
K.Daube
Apr 6, 2018 9:48 AM UTC
Hi Cameo,
Since the standard FM "Insert special character" is very meager I wrote a script serving my requirements. Not everybody has the same requirements, so the script is source code and you can change the symbols in there - use Unicode symbols only.
See Enhanced Toolbar for FM-14-en . On Request you can get the script alone.
Barb Binder
Apr 3, 2018 1:44 AM UTC
Hi Cameo:
Or, for ≤ type Ctrl+q # and for ≥ type Ctrl+q 3, then use a character tag to change the font to Symbol.
(These are sequential shortcuts, so for the first one, hold the Control key and press q. Release both and then type either 3 or Shift+3.)
~Barb
Apr 3, 2018 2:51 PM UTC
Hi Barb,
Ctrl+q # works for me perfectly! However, Ctrl+q 3 turns into a square when I change the Character Tag in the Character Designer pod to "SymbolFont."
Cameo
Barb Binder
Barb BinderCommunity ExpertCorrect answer
Hi Cameo:
~Barb
Jeff_Coatsworth
Apr 2, 2018 8:57 PM UTC
Unicode U+2265 (\u2265) ?
