Ran_techwriter
In FM2019 64-bit, has anyone had difficulty controlling text flow (top-to-bottom) in a two-column page layout?
  • February 5, 2019
  • 973 views
I'm running FrameMaker 2019 64-bit in Win 10. It's terrific in a single-column page layout, but I've had difficulty controlling text flow (top-to-bottom) in a two-column page layout - despite experimenting with various paragraph tag styles and anchored frame settings, the text flows (auto word-wraps) to the 2nd column before flowing top to bottom in the 1st column, and paragraphs of text can end up out of order depending on the paragraph tag styles applied and/or anchored frame placement on the page. Have other FM2019 users encountered this problem, and if so, how did you manage it? Thank You.
Correct answer Barb Binder
Ran_techwriter:
Column balance may be impacting the flowing to the second column before filling the first column. And are you using straddled heads (Pagination > Across all Columns)? Are your anchored frames or tables set to Float?
All of these will impact the text flow. I lay out a long two-column document with no issues. If you aren't sure what is going on, screen shots with borders and text symbols showing will help narrow this down.
~Barb
Barb Binder
Barb BinderCommunity ExpertCorrect answer
Ran_techwriter:
~Barb
Ran_techwriter
BarbBinder - Yes, I experimented with the Column Balance and Pagination settings throughout the document, which helped - but text flow was still surprisingly problematic to manage, partially due to project requirements (e.g., the presence of "excess white space" on the page is discouraged). I'm encouraged by your comment that you're able to create a long two-column document with no issues, so I'll continue to work with those features and refine paragraph tag styles and anchored frame settings going forward. Thank You.
Hi Ran_techwriter,
I also use a two-column layout with balanced columns.
There are a few bugs so that sometimes the balancing does not work.
Or paragraphs from the end of the second column appear at the end of the first column. When you move the insertion mark with the arrow keys, the insertion mark moves from the end of the second column to the end of the first column and then back to the second column.
I hope that these bugs get fixed with one of the next updates!
Best regards
Winfried
