Structured Frame 10 to DITA conversion
  • October 18, 2013
  • 1360 views
I have almost 3000 pages of sturctured Frame 10 docs that I need to convert to a new approach of using DITA.  Have anyone done this without using IXGen - merely using what Frame 10 has to offer?  IF so - any tricks you can provide?
Correct answer ScottPrentice
IXGen has nothing to do with a FM to DITA conversion. IXGen is an indexing plugin for FrameMaker.
There are a few ways to convert FM documents to DITA ..
- FrameMaker conversion tables
- MIF2Go
- Stilo Migrate (cloud-based tool)
- Consultant or other 3rd party
Here's some info and a presentation I gave for Adobe on the conversion table method ..
     http://leximation.com/downloads/adobe-fm2xml-2013
Cheers,
...scott
Scott Prentice
Leximation, Inc.
www.leximation.com
Hello Larrye-Marie,
Stilo Migrate can easily convert FrameMaker files to DITA xml.
The conversion process is almost automated with a very little human intervention (need to prepare a high-level rule set to guide the conversion).
You can go to the bottom of the webpage below and click "Free Offer" link for a sample conversion.
https://www.stilo.com/dita-xml-conversion-services/
Below is a short Youtube video about how Migrate converts a FrameMaker file to DITA.
https://www.youtube.com/watch?v=xNF41RfcyUs&t=167s
Thank you!
ScottPrentice
I'm not sure I'm following the question. What's the connection between IXGen and DITA? Last I knew IXGen didn't work with XML .. is that the issue you're concerned about?
...scott
October 21, 2013
To clarify, I found one solution but it requires IXGen and I am not in a position to purchase any additional software.
The issue is - HOW do I convert Framemerk documents to DITA if the docs are Framemaker 10 books and chapters.  Thanks
ScottPrentice
ScottPrenticeCorrect answer
- MIF2Go
Cheers,
...scott
Scott Prentice
Leximation, Inc.
www.leximation.com
