Task topic ignoring <info><note type="warning"></info> , <info><note/></info> works fine.
When converting a task topic to FrameMaker with a <note type="warning"> wrapped in an <info> element doesn't seem to flow down to the attribute type="warning (or caution)".  Even when the note is selected, the Structure View still shows the parent step or substep element. My EDD includes:
If context is: step
Use paragraph format: step.info.continue
Else, if context is: substep
Use paragraph format: substep.info.continue
Else, if context is: note [type = ”caution”]
Use paragraph format: caution
Else, if context is: note [type = ”warning”]
Use paragraph format: warning
But the type is not getting resolved.
Jeff,
Also, the out of the box EDD doesn't include the Context Rules for note[type="warning"]. I added them to the EDD and applied the updated EDD to the book templates hoping that it would work after the default didn't.
-Bruce
Jeff_Coatsworth
Sorry, I'm strictly a self-taught unstructured FM user myself - need some people like @frameexpert or @Matt-Tech Comm Tools who know structured FM to chime in.
Update:
Is working IF it is {notfirst}:
Doesn't work when "Local LOTO...." note is move from first out of <info>.:
I'll get it!!
Jeff_Coatsworth
What version of FM are you using?
Jeff,
Thanks for your reply. I've recently updated to 17.0.4.628.
Bruce
