Jul 11, 2020 7:16 PM UTC
Will Fresco work with surface pro and cintiq pro?
I'm aware of the fresco not compatible with cintiq pro.
But it is compatible with surface book / surface pro etc.
If i connect a surface pro (via mini displayPort) with cintiq pro and draw on the cintiq. Will it work?
Sue Garibaldi
Jul 13, 2020 4:56 PM UTC
Hi Arielnn.
Assuming your Surface Pro is compatible with Fresco (check the list here: https://helpx.adobe.com/fresco/system-requirements.html) you should be able to use your Cintiq with it (my understanding is that the only problem is panning).
Hope that helps.
Sue.
lalamelina
Jul 11, 2020 9:20 PM UTC
I have been using Fresco on a Surface Pro for a few weeks but as of yesterday, my documents are not saving properly. I spent hours on two projects only for the artboard to be blank when I came back to it. Not sure if it's related to a new update as I haven't been able to find any answers on why this is happening. Was working just fine before yesterday.
