adobe illustrator copy and paste problem
  • November 15, 2023
  • 572 views
Why does my Adobe Illustration always lose the font style when copying and pasting text, and then when copying and pasting files containing text in complex graphics, only the text appears? How to restore settings
Monika Gause
you have to search for that third party app in your system that interferes with the clipboard.
Maybe of of these:
  • Parallels Toolbox running with the Clipboard History
  • TeamVewer Clipboard > Use Shared Clipboard
  • Apple iOS device simulator from Xcode
  • Windows Multi-clipboard
  • Windows Clipboard History
  • Chrome Remote Desktop
  • Mouse Pointer Highlighter
  • AnyViewer
  • Pastebot app
  • Overzealous antivirus (Digital Guardian) as well as viruses that empty the clipboard
The problem described has not been solved yet. The problem I encountered is exactly the same as the one in this post.
https://community.adobe.com/t5/illustrator-discussions/copying-artwork-results-in-pasting-only-text/m-p/14235964#M387750
Monika Gause
Did you read that complete thread and tried everything?
Did you also try and reset your preferences (this will erase all your settings)?
Did you go through my list and checked all those items?
