Click-Move-Click Method Instead of Click-Drag-Click
Hello. I've customized the workflow in Illustrator to make it more similar to SketchUp and so far it's ok. The method of drawing however is one thing that I have difficulty with. In SketchUp you normally click-move-click, to draw lines, circles etc. In Illustrator it's click-drag-click (you must not release the mouse button). Any chance of having a click-move-click method? Thank you.
