thaleas76694366
Corner widget not visible on every corner
  • July 24, 2018
  • 16 replies
  • 109357 views
hi all,
although the interactive corner feature is really useful, unfortunately i cannot use it anymore. My problem is, that i can't see the corner-widget for all corners anymore. "Not anymore" because everthing worked fine and probably i made some changes in the settings or changed my workflow, and now i can't figure out where the issue is.
So you can see in the screenshot, that for some corners the widget is visible, for some not.
I already tried to play with the settings for corner-widget and also tried to convert the object into shape - nothing worked.
What is also interesting: sometimes when i try to convert an object into shapes i just get a message "object was not converted".
The issue mainly appears on objects wich i converted before (object -> path -> outline stroke). Objects which are created out of the rectangle tool, show all corner widgets.
This one is created via pen tool -> object -> path -> outline stroke:
This one is created via rectangle tool:
So, does anyone have an idea where my issue is?
Thanks for your help!
Correct answer Aeraf
i have had the same issue with my version CC 2022.  go to View >> Show edges.  this should solve the problem. did for me. thanks.
Adam Luke Sinclair
I just figured this out myself too! My object was too small. I enlarged it, applied the rounded corners and then reduced it back to size and that's fine. Hope Adobe will fix this bug one day.
Joe Hirst
Had a very similar issue, with a very simple fix.
Scaled my objects up a few hundred percent (I was working on rather small scale objects to save canvas space) and my radius handles appeared. I assume this is a bug, as I've never had this issue before. Adobe Illustrator Version 29.1
Missing radius handles on smaller scaled objects - Fix is to scale the object
AerafCorrect answer
I've just figured it out.
For me it was happening because there were two vertices right on top of each other.
Click select (Not drag selection) the vertice in the corner you're having a problem with the Direct Selection tool and move it, there will be most likely two points right on top of each other. So move one out of the way and delete it and it should show the Corner Widget.
THIS IS THE FIX! It's common especially when merging or dividing shapes... you can have multiple anchor points directly on top of one another. I simply moved the point with the correct handles down and used the Delete Anchor Point Tool (-) to removed the extra anchor point. Sure enough the corner radius widget popped up!
The Vector First Aid plugin from Astute Graphics is really good at automatically cleaning up instances of two or more anchor points sitting on top of each other. The plugin will typically delete the stray points without affecting the shape of the path.
The scale thing nor the handle display was my problem. It was the pref below saying Hide C. Widget on angle greater than... I set it to 105 degrees from its default of 3 degrees.
Shift+Ctrl+B= Solved! 100%
Monika Gause
quote
By @Md Mohidul Ho25751089865b
Please read the complete thread.
This will solve your problem.
I was encountering a super strange situation that i wanted to document here for anyone that is struggling (been several hours of digging to figure this out.)  I scaled a set of paths that all had corner anchor points (and corner widgets), and this got rid of the corner widgets.
i reverted to an old version of the document with corner widgets available, then scaled via direct selection tool - this confirmed to remove corner widget on anchor points (and converted each single original corner to two smooth anchor points)
undid the change then scaled via the object selection tool - this kept the anchors as corners, and corner widgets as expected
Chris Webb | REALTOR®
I noticed that you can't scale an image AFTER you've adjusted the corners without losing the bottom widgets (on a rectangle). Scale the image first, then scale the corners and the widgets will stay.
I was having the same trouble with an object I made using the shape builder tool. If you add an anchor point directly next to the point that doesn't have a widget and delete the widgetless point your new point should have the corner widget. Then you can just move the new point back to the correct position.
lindseyf15356646
I commonly have this problem too. For me, what has usually worked is:
1. there are two points on the corner (when I have outlined a path, this commonly happens.) I just delete the extra point and the live corner will show up (sometimes, there are multiple points all on top of each other, make sure you delete them all!)
2. The object is too small, so I just scale up and make my corners how I like them then size back down.
Thank you so much @lindseyf15356646 ! I was able to resolved my issues by following your steps. It worked! 🙂
