Ctrl + Shift + O shortcut (Create Outlines) doesn't work.
  • July 18, 2018
  • 20 replies
  • 24923 views
The keyboard shortcut for Create Outlines doesn't work.
I need to use the menu Type/ Create Outlines. It's really annoying.
I've tried to change the shortcut, open another document, but nothing worked.
The other shortcuts using Ctrl and Shift work (like Ctrl + for zoom...).
Usually, I select all the artwork (Ctrl + A) then Ctrl + Shift + O to Create Outlines. It doesn't work.
Started at least a month ago.
I'm using Illustrator CC, the most updated one.
Could someone help me? Thank you!
Correct answer Chris@Gear
If you have an AMD video card, check in Radeon Settings -> Gaming -> Global Settings -> Performance Monitoring.
Click "Toggle Performance Overlay Hotkey" and change it to something other than Ctrl + Shift + O, or just hit Delete to specify None as a hotkey.
That solved the problem for me. Illustrator now receives the Ctrl + Shift + O key combo just fine.
Funcionou, obrigado!
Chris@GearCorrect answer
Larry G. Schneider
Thanks for posting this solution. It will help others.
John Mensinger
Have you tried resetting preferences?
Not yet. How can I do it?
Bill Silbert
To delete preferences:
For Macintosh Users: With Illustrator closed launch a Finder Window in column view and click on your home folder. With the Option Key pressed choose Library from the Finder Go Menu. Within the Library folder find the folder called Preferences and within it find the following two files and delete them: “Adobe Illustrator <Version #> Settings” (earlier versions of Illustrator might just say “Adobe Illustrator”) and “com.adobe.Illustrator.plist”. When Illustrator is next launched it will create new preference files and the program will be restored to its defaults.
For Windows Users: You can try the quick way of resetting on a PC which is to hold down Ctrl + Alt + Shift when launching Illustrator and respond affirmatively when asked if you want to reset. There have been some recent reports that the window asking if you want to reset is not popping up but that the prefs are being reset anyway. If this works great but if it doesn’t you may have to manually delete them.
To do so:
On Windows 7 and above the preference files are hidden. To find them go to the Control Panel and open Folder Options and then click the View tab. Then select “Show hidden files and folders” or “Show hidden files, folders or drive options” in Advanced Settings. Then delete (or rename) the folder at the end of this path: C:\Users\[User Name]\AppData\Roaming\Adobe\Adobe Illustrator [version number]\ Settings\<Language>. Make sure that Illustrator is closed when you do this. When you relaunch the program it will create  new preference files and the program will be at its default settings.
The advantage of manually deleting preference files is that after you’ve reset up the program (make sure that no document window is open) to your liking, you can create copies of your personalized “mint” preference files (make sure that you quit the program before copying them—that finalizes your customization) and use them in the future to replace any corrupt versions you may need to delete.
