ChrisKES2018
Drop Shadow not showing on Artboard
  • November 27, 2018
  • 8921 views
I created a drop shadow behind a logo and it shows when the logo is off the artboard but when I move the logo into the position that I want it the drop shadow seems to disappear.  The second photo below is once I move it into position. I tried to see if it showed when saved and it did not.
Correct answer Monika Gause
White is gone when multiplied. Always.
You can't compare it to what you see on the document canvas, because that is not an object. If you want your white to be visible, don't use "Multiply", but "Normal" or "Lighten or one of the other lightening blend modes.
Monika Gause
So the white thing on dark background is the shadow? Which blend mode did you use? And which document color mode is this?
ChrisKES2018
Yes, the white thing is the drop shadow. Does this photo help? I go to effect -> stylize -> drop shadow.
Monika Gause
Monika GauseCommunity ExpertCorrect answer
Bill Silbert
How did you create the drop shadow? As an effect or as a separate element?
ChrisKES2018
As an effect
