Resuelto
Fix Shape - Jagged Edge
  • September 18, 2023
  • 2 respuestas
  • 986 visualizaciones
Hello, all. I am designing an icon for a client and I can't for the life of me figure out how to make this line straight. Notice how there's a sharp (jagged) edge sticking out. 😕😕
Este tema ha sido cerrado para respuestas.
Mejor respuesta de Monika Gause
There is a corner in the outline as well. So there are no anchor points to delete there?
2 respuestas
Ton Frederiks
Can you show something when selected? Maybe alson an Outline View?
Sure. I've attached the outline view.
Monika Gause
Monika GauseCommunity ExpertRespuesta
Larry G. Schneider
Does it look any different if you use View on CPU? If it does it's just an artifact and probably won't print.
Yes, it still looks the same.
