Sep 30, 2024 5:29 PM UTC
HELP Illustrator 28.7.1.: 3D and Materials effect still noise & low quality after rendering on high
I'm trying to excecute the 3D and Materials design on a simple star (and on other vectors) and I always get a low quality result. Nothing like all the YouTube videos after rendering on high quality and reducing noise.
I always end up with some noise around the edges and it just doesn't look good.
My graphic card is NVIDIA RTX 4060 version 537.70
The star is attached
Can someone please help here?
Thanks
Anubhav M
Sep 30, 2024 5:40 PM UTC
Hello @diane_6656,
Thanks for reaching out. Would you mind sharing some more details, like the exact version of the OS/Illustrator, a public link to a sample file after uploading it to Dropbox/Google Drive/etc., and a screen recording of your workflow and the problem (https://adobe.ly/47NF4nk), so we can better assist you?
Looking forward to hearing from you.
Anubhav
Sep 30, 2024 6:18 PM UTC
Hello Anubhav,
Illustrator version is 28.7.1. on a Windows 11, graphic card is NVIDIA RTX 4060 version 537.70
I took a video but is there a way to share it privately for support, since my email address would be public in that way.
Anubhav M
Sep 30, 2024 6:34 PM UTC
Hello @diane_6656,
Thanks for confirming. You can attach the video directly here or share it with me via DM.
Anubhav
