juliam56342833
How to export png the same size as artboard and keep the same quality
  • December 18, 2019
  • 7969 views
Hi.  I can export a png that's the same size as my artboard by going to File>Save for Web, but I lose image quality even if I choose PNG-24.  If I choose File>Export As and choose png at 300 resolution, the quality is great but it increases the image size, and if I bring it into Photoshop and decrease the size with Image Size while keeping the same resolution and choosing Bicubic Sharper, I still loose quality.  Is there a better way I can do this?  Thank you.
Monika Gause
You won't keep the same quality. PNG is a pixel image. You cannot zoom in.
John Mensinger
That depends on your ultimate objectives for the graphic. I almost never work in Illustrator when the output is to be a raster image, but on those rare occasions when I have, I was never satisfied with raster-format export. If the PNG-destined elements are simple, set up a Photoshop canvas at the desired final size and resolution, then simply copy and paste from Illustrator. For more complex artwork, save (in Illustrator) as PDF, then open that in Photoshop to rasterize at the desired final size/resolution. In either case, PNG output from Photoshop will offer more control and better results.
Jacob Bugge
This may sound unforgivably outdated and boring, sorry.
If you wish to have PNGs (PNG24, of course) look crisp and clean, it is important to have the images in the exact desired final pixel x pixel size, forget about resolution which may actually lead to wrong sizes and hence blurriness. It is easiest and safest to work at the desired size.
A very common unsuitable way is to Export to PNG (remember to use PNG24 and use Transparency for artwork to be in front of different backgrounds) with a medium or high resolution, such as 300PPI.
To retain the clean and crisp artwork, a PNG must be created at exactly the pixel x pixel size that it is to be used for (or second best at sizes that are powers of 2 times as large).
For clean and crisp artwork avoid JPEG.
It is also important to have the artwork and also the Artboard placed fully within integer/whole pixel X and Y values in the Workspace. Otherwise the resulting image will become a bit wider/taller and the extension(s) will be empty and therefore be white.
Therefore, the safest way is to create the artwork at the final pixel x pixel size and use a corresponding Artboard, then either use the Legacity Save for Web (where you can look in the Image Size window for size confirmation) or Export at 72PPI. In either case, use the relevant optimization (available with both ways); it is also convenient to have 72PPI in the Effect>Document Raster Effect Settings.
If you have pure vector artwork, you can relax a bit and have the artwork/Artboard at any size (the Artboard must have the same proportions as the final image), then use the Legacity Save for Web and set either Width or Height in the Image Size and Apply (make sure the other value is also correct).
The Legacy Save for Web may be an old carthorse, but it knows its way home, even if the driver is drunk and sleeping it off in the hay in the back.
