Illustrator Paste in place doesn't work Versions 2023/2024
  • February 15, 2024
  • 218 views
Paste in place does not work when copying out of illustrator 2024, into illustrator 2023. It places the art at 0,0 on the artboard instead of the original location. It also has the unfortunate side effect of putting the various elements into clipping masks.
Why did Adobe not make Illustrator 2024 backwards compatible with 2023?
Ton Frederiks
You can open your 2024 files in 2023, What happens if you copy and paste in 2023?
If you use features in 2024 that were not available in 2023 you may encounter these clipping masks.
