ILLUSTRATOR (stroke showing when stroke not applied
- May 22, 2022
- 3 replies
- 1016 views
So I figured out the issue. Due to the shapes in question belonging to a group, which were emanating from different steps in the creative process, there were multiple appearances within the group that were not matching according to the Appearance Panel, even when changing the Fill Color to the group as a whole. The solution I found was going into the group in Isolation Mode and clicking "Clear Appearance" in the Appearance Panel dropdown, and then selecting the entire group outside of Isolation, and choosing the desired color. This removed the odd stroke that was present in my previous screenshot. Thank you for your assistance and I hope this helps someone!
