Issue with COPY+PASTE working and not working
  • January 24, 2025
  • 1291 views
Hi
I've been having a recurring problem - and I BELIEVE IN ALL ADOBE SOFTWARE - but especially in Illustrator which is what I use 99% of the time (but I've had the same problem in Photoshop)
Initially I thought it was a problem with my hardware - but I bought a NEW machine -
TOP OF THE LINE:
INTEL CORE ULTRA 9 285K with 96GB of RAM
and I still have the same problem:
COPY + PASTE works only when the software wants it to.
SOMETIMES OK
SOMETIMES NOT.
Sometimes I click COPY+PASTE - and done. works.
Sometimes I click COPY+PASTE - and no PASTE. I open the menu EDIT> and no "COPY" too (EDIT menu doesn't have the option "PASTE" - it's "off" = gray) - I need to click, click, click, click - for the "COPY" works and then the "PASTE" option turns "on".
any idea?
The problem persists here. COPY-PASTE works "when it wants to"
And not only via keyboard (to isolate the problem) - the same thing happens when clicking directly on the menu:
EDIT > COPY
with the mouse.
You can see that even when clicking on "COPY" the "PASTE" option is not active.
Suddenly, with any click, it activates.
NO THIRD PARTY SOFTWARE INSTALLED.
 really frustrating
Monika Gause
quote
By @Daniel_Rodrigo
Nothing from the list? No browser?
No. and the same issue occurs with another computer.
koala_geddon
I’ve had issues with the copy-paste function randomly not working at times, which can be really frustrating. Usually, restarting the application or clearing the clipboard helps, but sometimes it's a deeper issue related to software conflicts. Has anyone found a reliable fix for this?
Anubhav M
Hello @koala_geddon,
Would you mind trying to run Illustrator under Safe Mode (Windows / macOS) and checking if it helps? If yes, try running with your usual set of applications one at a time to find the conflicting application and share your observations.
Looking forward to hearing from you.
Anubhav
Monika Gause
Several third party apps are known to interfere with Illustrator's clipboard. Here is  list of apps and settings that have been identified by people in this forum to do that.
  • Parallels Toolbox running with the Clipboard History
  • LogoTech Keyboard management software
  • TeamVewer Clipboard > Use Shared Clipboard
  • Apple iOS device simulator from Xcode
  • Windows Multi-clipboard
  • Windows Clipboard History
  • Clippy
  • Chrome Remote Desktop
  • Mouse Pointer Highlighter
  • AnyViewer
  • Pastebot app
  • Overzealous antivirus (Digital Guardian) as well as viruses that empty the clipboard
  • Vector Magic
