Issue with the Thonburi Font from OS System Fonts
  • September 24, 2021
  • 1476 views
The Customer I work for uses Thonburi for their Thai language. When using the font in Illustrator 2019, 2020 or 2021 the font displays incorrectly. Illustrator 2018 work fine.
We don't want to remove the font from the system fonts because that could cause more issues.
Has anyone ever come accross this issue and if so, is there a fix.
Anshul_Saini
Hi there,
Sorry about the trouble, You may try the steps suggested in this help article (https://helpx.adobe.com/illustrator/using/asian-scripts.html) step by step and let us know how it goes.
I hope it helps!
Thanks & Regards,
Anshul Saini
Hello. This did not fix my issue.
Any other suggestions?
Dave
Anshul_Saini
Thanks for trying the steps. Is the issue related to a specific document? If yes, could you please share the document with us? You can upload it to the Creative Cloud (https://helpx.adobe.com/in/creative-cloud/help/share.html) and share the download link here or via DM. I will be happy to take a look at it.
Anshul Saini
