Keyboard Increments setting does not fix inability to move objects with arrow keys
  • August 1, 2024
  • 379 views
I have tried everything including setting the keyboard increments, but the arrow keys do not move objects in illustrator. Can anyone advise?
Correct answer Jeanie38942746c9kb
Did you already reboot the system?
Reset the preferences?
It finally worked after rebooting the system. Thank you!!
Monika Gause
What did you set it to?
Can you use the arrow keys to move the curosr in text entry fields in Illustrator?
It was set at 0.0139. I cannot move the cursor in text entry field either.
thanks
Jeanie38942746c9kbAuthorCorrect answer
