Hi all, I'm trying to use the new Beta feature "Mockup" but it's greyed out. I've followed the same steps as someone in a youTube video but mine doesn't work.
it doen't seam to be there juts yet anyways.. if you have a complex lable Ai can't handle it. this add on is for small etsy users and home brew tshirt mock ups.. hopefully in a year they can get it up to speed.. it doesn't like multipul clipping masks i'm noticing, or graphic styles.. pretty cool to know this is something that they're working on
I figured it out. You have to create a mask on your object first. Kind of like how you would prep a logo for a decal or sticker with a cut line. Once it has a clipping mask on your entire art layer it will endable mock-up
The label can only be vector artwork. A placed PNG is not vector artwork. If the label artwork is in a different file, then you can copy it from there and paste into the file with the photo.
Ok, ill be the dumb one ......what file extension is a vector? I thought jpeg was vector. Photoshop does not save as or export svg.
