Problems with .hasOwnProperty
  • January 30, 2019
  • 1427 views
Hello
I have a problem with a JavaScript method : hasOwnProperty.
I want to test this property and ESTK don't work correctly.
My little code :
alert(1)
if(Array.prototype.hasOwnProperty("push")){
    alert("hello)
alert(2)
Normally, I have 3 alerts (1, "hello" and 2) but ESTK send me 2 alerts only (1 and 2).
ESTK send me false for condition if.
I share with you a Youtube video : hasOwnProperty - YouTube
I tried on development console and Google send me 3 alerts (1, "hello", 2).
Sometimes, ESTK send me true for condition only if I changed argument "push" to "pop" or "push" to "join" before, for example.
Can you help me for this problem, thank you.
Silly-V
hasOwnProperty is only going to find properties that belong to an instance of an object, but not the prototypes or any class-owned properties.
See the test below: you can check typeof() to see if the item in question is a function, another datatype, or undefined.
    var arr = [1,2,3];
    alert(arr.hasOwnProperty("push")); // false
    alert(arr.hasOwnProperty("0")); // true
    alert(arr.hasOwnProperty("4")); // false
    alert(typeof(Array.prototype.push)); // function
    alert(typeof(Array.prototype.donaldDuck)); // undefined
Ok but if Object.prototype have hasOwnProperty method, it's strange I can't use it for build-in object, no ?
Silly-V
Well, in that case it's probably differences between the ES3 and ES5 javascripts.
Probably in ES3 they didn't have the prototype object souped-up like in our modern-day browsers!
EcmaScript 3 VS EcmaScript 5 - Jie Huang's Blog
CarlosCanto
what are you trying to achieve?
you suppose to use the "hasOwnProperty" function on objects you create yourself
for example
var myArray = [1, 2, 3];
myArray.id = 10;
alert(myArray.hasOwnProperty("id"));
Hello, sorry for late and thank you for your answer
I want just know why hasOwnProperty don't work correctly on ESTK but yes in Chrome
CarlosCanto
oh ok
