Purpose of small white triangle at top-right corner of a layer (in layers panel)?
  • June 21, 2018
  • 2174 views
As the topic name imples:
I'm using Illustrator CS6.
Thanks
    Correct answer Kurt Gold
    It's just an indicator that tells you that the highlighted item in the palette is a main layer or a sublayer. It can be helpful if you are working with nested layers that contains a lot of sublayers and groups because groups are not marked with the triangle.
    It's not necessary to click on the triangle to select all objects on a layer. You can just click somewhere in the right column of the layer item.
    Kurt Gold
    Kurt GoldCommunity ExpertCorrect answer
    Monika Gause
    it indicates the active layer (the one you draw on)
    Bill Silbert
    You can click on it and it will select all objects on the layer.
