"Return" will not be captured with Script UI
  • November 11, 2025
  • 426 views
Thsi Script exports PDF files to a given folder without saving the current AI-file.
When one of the dialoge windows is open, I can navigate through the options and choose them with space-key. So the button gets blue higlighted but the predefined keeps its white outline. But hitting "Return" an the blue colored button, will not work at all. It will activate the white outlined button.
Space will activate the blue higlighted instead, like one would expect it from "Retrun", too.
Any idea how to capture "Return" when choosing e.g. "Abbrechen" in this dialogue?
function askDocumentChoice() {
    var dlg = new Window("dialog", "Welche Dokumente speichern?");
    dlg.add("Group {orientation:'row', alignment:['fill','top']}").add("statictext", undefined, "Sollen alle geöffneten Dokumente gespeichert werden?");
    dlg.add("Group {orientation:'row', alignment:['fill','top']}").add("statictext", undefined, "(oder nur das aktuelle?)");
    var buttonRow = dlg.add("Group {orientation:'row', alignment:['right','top']}");
    var btnCurrent = buttonRow.add("button", undefined, "Nur aktuelles");
    var btnAll = buttonRow.add("button", undefined, "Alle", { name: 'ok' });
    var btnCancel = buttonRow.add("button", undefined, "Abbrechen", { name: 'cancel' });
    btnCurrent.onClick = function() { dlg.close(0); };
    btnAll.onClick = function() { dlg.close(1); };
    btnCancel.onClick = function() { dlg.close(-1); };
    dlg.defaultElement = btnAll;
    dlg.cancelElement = btnCancel;
    dlg.center();
    return dlg;
RobOctopus
I don't see your dlg.show() line anywhere, but writing it to say "return dlg.show()" will return the number values passed through the .close() method.
    btnCurrent.onClick = function() { return dlg.close(0); };
    btnAll.onClick = function() { return dlg.close(1); };
    btnCancel.onClick = function() { return dlg.close(4); };
    return dlg.show()
alert(askDocumentChoice())
0771Author
While btnCurrent is blue, Space will return "0" and Return will return "1"
m1b
No it does not ... this way Return button will keep fokus on activated ... so it simply does not work
@0771 I'm not understanding what you want to happen. Do you want to be able to override the normal behaviour which is that pressing Return triggers the designated "OK" button (the window's defaultElement)? In other words do you want pressing Return to work like pressing Space?
m1b
Hi @0771 the Return key will trigger the onClick handler for the button whose `name` === "ok".
Similarly, the Escape key will trigger the button named "cancel".
Does that answer your question or have I misunderstood the point?
-Mark
0771Author
@m1b so while Space key can trigger all, Return will always and only capture "ok"?
m1b
Yes return will trigger "ok" button. Space will trigger the active control.
0771Author
Sorry for the wrong grammatic, but I cannot edit my post anymore... So I just wanted to add I navigate with Tab-key through the different buttons.
0771Author
