nanf80115613
Feb 9, 2026 9:43 AM UTC
Crash when using Liquify over an image after early mesh work, so using straight to apply to a new layer or mask. Also big problems with Select and mask, thinkingggggggggg
You do a Liquify correction, if you like to do it again straight from menu it crash.
Select and mask crash too with any image.
    CShubert
    Feb 9, 2026 3:37 PM UTC
    Hi ​@nanf80115613 could you share a video or steps you use that create this crash?  Do you have the same issue with Ps release version or just Ps Beta?
    Cory - Photoshop Product Manager
    nanf80115613
    Feb 10, 2026 8:26 AM UTC
    Hi.
    Apparently it’s not happening anymore, probably since the last update. I’ve been working on a project for a few weeks and had stopped using that method to make adjustments. I tried it again today and it seems to be working fine. Thanks.
    The process was: PS Beta
    1. Image layer > Liquify (panel)
    2. Mask layer > Liquify (again)
    3. Crash
      Thanks for reaching out.
