FireFly does not work correctly
  • July 9, 2025
  • 276 views
Hi. In new Photoshop-Beta FireFly does not work correctly.
1. When I upload reference picture - I can not write the text of prompt. And conversely - after writing prompt I can not upload reference. So, I can not use prompt and reference together. But in earlier versions of Photoshop-beta it worked.
2. After uploading reference Photohop cuts out part of the image - so, the reference image does not uploading whole.
Kevin Stohlmeyer
@Morfozavr can you supply samples of the reference image and prompt you are trying to use?
MorfozavrAuthor
look at these explanations, please.
MorfozavrAuthor
My suggestion is to not mask the image prior to generating, mask after you have your results.
But I do not make any mask.. I just make selection of needed region on image.  And why does Photoshop make mask (cuts) of reference image?
kglad
<"moved from cc desktop">
