SREEHAS ABRAHAM
It does not allow me to generate with partner model. It just shows firefly, once I generate few times with firefly partner model shows up, very annoying
  • May 1, 2026
  • 53 views
Partner models doesnt show up when i try to generate , It only shows firefly in the begining and after few firefly generation partner models shows up, when i try to generate on a empty layer, there is no other models except firefly, once i generate with firefly and create new empty layer and try to generate then all models shows up, kindly fix the buy , very annoying. Thanks
    CShubert
    Hi ​@SREEHAS ABRAHAM please confirm you are using the latest Ps Beta…
    Adobe Photoshop Version: 27.7.0 20260429.m.3521 d10d509  arm64 (beta, PublicBeta)
    Are you on a single subscription or a Enterprise/EDU account?
    Cory - Photoshop Product Manager
    Trevor.Dennis
    They are definitely context sensitive.  i.e. some models require an area to be selected, and are not available if there is no selection.
    Are you having any trouble entering the prompt?
    It is refusing input for some people.
