Reference images not showing
  • May 17, 2024
  • 9 replies
  • 16880 views
I updated BETA 2 days ago and Reference Image is not showing besides the Generative Fill button, as it used to be a week ago
Nat
Correct answer CShubert
@Derek34596145w31n the Reference Image is only on Ps beta, not the Ps release version.  Did you mean to post this on the Ps forum for release?
Here is the post about Reference Image for reference:
https://community.adobe.com/t5/photoshop-beta-discussions/reference-image-beta-for-generative-fill-amp-generative-expand/td-p/14572828
Cory - Photoshop Product Manager
Has this been figured out yet? I am on PS v26.7 and the only place I can find it is here: https://photoshop.adobe.com/ Adobe on Web. Where can I download a version of the desktop app for Mac that has this feature?
No answers at all on this I guess?
Hi swshmn,
You should be able to access the Reference Image feature in PS Beta on the mac.
Same problem, no "reference image" icon appears next to the generative fill text field.
Mac OS, Photoshop ver 25.11
The reference image icon only appeards when I use the "Generate image" function, not generative fill
CShubert
CShubertCommunity ManagerCorrect answer
thank you for clarifying
jane-e
quote
By @TahiaDesign
I've moved your post to the Photoshop Beta forum.
Jane
Z3ROCOOL22
I'm on 25.12.0 and i can see the reference icon without problem:
I'm having the same issue. Weirdly enough I was using it last night and the icon was there but this morning the reference image icon is gone. Using version 25.9.1 Beta Photoshop
I totally agree with you. In general, generative fill is pretty useless without reference image option.
The Reference Image feature is not in the released version of Photoshop yet, but you should see it in the Beta
I have the same issue. The photoshoop version is 25.9. Any updates here?
Hi Same problem. My photoshop is updated and I have been looking for help for this issue.
I got the same problem
Hi Tahia,
Please open an image, make a selection, and then place your insertion point in the “Generative Fill” field of the context bar. If the reference image button does not appear, please share a screenshot of your screen.
Thanks!
