NIKOS PLATIS
AI Tools & Camera Raw & GPU problem
  • April 24, 2026
  • 86 views
When i use some tools that use AI (remove tool from either menu or Contextual Task Bar), after a few uses on the same photo, this tool stops working properly. When this happens, Camera Raw does not open at all. It gives me an error "Could not complete the Camera Raw Filter command because of a program error". When i try to open Camera Raw again it says "camera raw requires graphics processor acceleration to edit photos". That started happening one week ago.
Two weeks ago I changed RAM from 16GB to 32GB. It’s the same type RAM the only difference is that it’s 32GB. PC recognizes the RAM.
Processor:           AMD Ryzen 5 2600 Six-Core Processor               3.40 GHz
Installed RAM:    32.0 GB
Graphics Card:    NVIDIA GeForce GTX 1050 (2 GB)
System Type:      64-bit operating system, x64-based processor
Edition:    Windows 10 Home
Version:   22H2
Photoshop 27.5.0
Until last week all worked fine. This problem started on Monday and it drives me crazy as I must restart Photoshop each time I manage to finish editing one (1) photo !!! Then the problem i described above appears.
I have tried all the solutions i read on the internet but nothing!!!
NVIDIA is up to date, Photoshop is up to date, Memory usage in Photoshop is 70% - 80%, Use Graphics Processor is not checked, Remove Tool Processing: More Stable.
I am literally lost as I don’t know what else to try…
See below - attached herewith Photos for easy reference
NIKOS PLATIS
Problem still persists. However I noticed that this “glitch” like problem happens only when i use the Remove tool a few times, either from the Tools Bar or contextual bar.
After two - three times of using the Remove Tool, the problem appears and I must restart Photoshop until i use the Remove Tool again for two - three times more and then problem appears again, then restart Photoshop again and so on...
Any suggestions?
D Fosse
Do you have generative AI on or off? Generative AI needs to communicate with Adobe’s servers.
NIKOS PLATIS
Actually it doesn’t matter. I had it turned on (same problem), then i turned it off (i have it off), same problem.
Also in Preferences → Image Processing → Remove Tool Processing is in More Stable
D Fosse
My immediate thoughts are that a GTX 1050 with only 2GB VRAM will struggle with some functions today. While it should work well for basic functionality, some advanced functions may hit a wall with this GPU. The general recommendation today is 12-16 GB VRAM.
Photoshop settings for memory and GPU do not apply here. ACR runs outside Photoshop’s address space and uses its own memory separate from Photoshop. Disabling the GPU in Photoshop does not disable it in ACR.
AI-based GPU functions put increased demands on the GPU with each consecutive ACR version. This is where the most rapid development happens these days.
NIKOS PLATIS
I have 32GB physical RAM.
I didn’t have any issues with my previous 16GB psysical RAM
Ged_Traynor
@NIKOS PLATIS have a look at the ACR troubleshooting steps here
https://helpx.adobe.com/camera-raw/kb/acr-gpu-faq.html
NIKOS PLATIS
Many thanks for the steps link.
I will get back to you once i try the suggested solutions :-)
