Brush Color Replacement Tool or Brush Mode Color Doesn't Work as Expected
- August 21, 2023
- 0 replies
- 384 views
When I use Brush, Color Replacement Tool or Brush, Mode Color the color I want to use to replace isn't what is replaced. The swatch shows the correct color in the Forground.
On a White or Black Background nothing is painted. If I use a lighter shade than a color I am overlaying it comes out gray or a darker shade of the color I am using. If I use a dark shade over a lighter shade I get grey or a lighter shade of the color I am using. The only time it matches is when you replace the same color with the same color.
I also attached a
I tried to clearly show that on the attachments. I also tried to change this robin egg blue 1951 Buick XP 300 GM Le Sabre to black to make it a Batmobile, but it turned silver instead.
I'm on Windows 11, ROG Zypher M16 Laptop, I also tested on my desktop Windows 10 with same results so I don't know how the issue could be on my end. I used Creative Cleaner to remove every Adobe app I have, I deleted the Adobe Common directory, so there was nothing left of Adobe on my computer. I turned off GPU though it behaves the same with it on. I state this so I don't get a lot of comments suggesting these as possbile solutions. I have had the same experience for the last couple of versions of regular and beta. This test was with the latest production v.24.7.0, but also failed on v25 Beta.
System Info
Adobe Photoshop Version: 24.7.0 20230719.r.643 efe3886 x64
Number of Launches: 1
Operating System: Windows 11 64-bit
Version: 11 or greater 10.0.22621.2134
System architecture: Intel CPU Family:6, Model:13, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, AVX-512, HyperThreading
Physical processor count: 8
Logical processor count: 16
Processor speed: 2496 MHz
Built-in memory: 16061 MB
Free memory: 10138 MB
Memory available to Photoshop: 11825 MB
Memory used by Photoshop: 69 %
Crash Handler: Adobe
DCX Version: 7.1.5
SAM SDK Version: 4.1.4
ACP.local Status:
- SDK Version: 3.2.0.1
- Core Sync Status: Reachable and compatible
- Core Sync Running: 6.5.3.1
- Min Core Sync Required: 4.3.66.28
Live Edit Client SDK Version: 4.0.0
Content Credential Helper Version: 0.5.3
D3D12Warp renderer: Disabled.
Manta Canvas: Enabled.
Alias Layers: Disabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 6
Font Preview: Medium
HarfBuzz Version: 4.3.0
TextEngine: Unified Text Engine
======= GPU
Native API stable: True
OpenGL API stable: True
OpenCL API stable: True
GPUDeny: 0
GPUForce: 0
useGPU: 1
useOpenCL: 1
isGPUCapable: 1
GPUName: NVIDIA GeForce RTX 3060 Laptop GPU
GPUVendor: NVIDIA
IsNativeGPUCapable: 1
IsOpenGLGPUCapable: 1
IsOpenCLGPUCapable: 1
HasSufficientRAM: 1
GPU accessible RAM: 6,009 MB
Required GPU accessible RAM: 1,500 MB
UseGraphicsProcessorChecked: 1
UseOpenCLChecked: 1
Windows remote desktop: 0
Windows available feature level: 12.2
Windows required feature level: 12.0
Windows has required feature level: 1
Display: 1
Display Bounds: top=0, left=0, bottom=1599.99, right=2560
------- Sniffer output
[0 ms]
Launch GPUSnifferThread
[1 ms]
Start RunAllAPIs
[1 ms]
"C:\Program Files\Adobe\Adobe Photoshop 2023\sniffer.exe" -baseTimeMS=272338861 -comment=Photoshop Version: Adobe Photoshop 24.7.0 20230719.r.643 efe3886 x64
[2610 ms]
Start sniffer 2023-08-20 03:32:20
# Photoshop Version: Adobe Photoshop 24.7.0 20230719.r.643 efe3886 x64
C:\Program Files\Adobe\Adobe Photoshop 2023\sniffer.exe -baseTimeMS=272338861 -comment=Photoshop Version: Adobe Photoshop 24.7.0 20230719.r.643 efe3886 x64
{242 ms}
Start platform native
# displays: 1
Display 0
Display: \\.\DISPLAY1
Main: TRUE
Built in: FALSE
Stereo: FALSE
Bounds: (0, 0) -> (1,707, 1,067)
Dimensions: (1,707 1,067)
Physical size: (0 0)
Pixel size: (0 0)
Dynamic range: (0 1)
Potential dynamic range: (0 1)
Reference dynamic range: (0 0)
Attached Device: (DeviceID name=NVIDIA GeForce RTX 3060 Laptop GPU index=0)
# devices: 2
Device 0
Preferred: TRUE
Power Envelope: UNKNOWN
Attachment: UNKNOWN
# attached displays: 1
\\.\DISPLAY1
VRAM: 6,009 MB
Dedicated System RAM: 0 MB
Shared System RAM: 8,420 MB
API version: 12.0 (12.0)
Device version: 12.0 (12.0)
Vendor name: NVIDIA
Driver date: 2023-08-04 000000.000000-000
Driver age: 0 months
Driver version: 31.0.15.3699
Supports UMA: UNSUPPORTED
D3D-ID: 9504
Device 1
Name: Intel(R) UHD Graphics
Preferred: FALSE
Attachment: UNKNOWN
# attached displays: 0
GPU accessible RAM: 8,548 MB
VRAM: 128 MB
Vendor name: INTEL
Driver date: 2023-03-16 000000.000000-000
Driver age: 5 months
Driver version: 31.0.101.4255
Supports UMA: SUPPORTED
D3D-ID: 39520
End platform native
{915 ms}
{915 ms}
Start platform OpenGL
# displays: 1
Display 0
Main: TRUE
Built in: FALSE
Stereo: FALSE
Pixel size: (0 0)
Attached Device: (DeviceID name=NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2 index=0)
# devices: 1
Device 0
Name: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2
Preferred: TRUE
Power Envelope: INTEGRATED
Attachment: UNKNOWN
\\.\DISPLAY1
GPU accessible RAM: 6,300 MB
VRAM: 6,300 MB
API version: 2.1 (2.1.2 NVIDIA 536.99)
Device version: 2.1 (2.1.2 NVIDIA 536.99)
Vendor name: NVIDIA
GLSL version: 1.20 (1.20 NVIDIA via Cg compiler)
End platform OpenGL
{1224 ms}
{1224 ms}
Start platform OpenCL
# displays: 0
# devices: 2
Device 0
Preferred: TRUE
Power Envelope: DISCRETE
Attachment: UNKNOWN
GPU accessible RAM: 6,441 MB
VRAM: 6,441 MB
Shared System RAM: 0 MB
API version: 3.0 (OpenCL 3.0 CUDA)
Device version: 3.0 (OpenCL 3.0 CUDA)
Vendor name: NVIDIA
Driver date: UNKNOWN
Driver age: UNKNOWN
Driver version: UNKNOWN
Bandwidth: 297 GB / s
Compute score: 4,743.47
Device name string: NVIDIA GeForce RTX 3060 Laptop GPU
Device vendor string: NVIDIA Corporation
Platform name string: NVIDIA CUDA
Platform vendor string: NVIDIA Corporation
Device 1
Preferred: FALSE
Attachment: UNKNOWN
GPU accessible RAM: 6,736 MB
VRAM: 6,736 MB
API version: 3.0 (OpenCL 3.0 )
Device version: 3.0 (OpenCL 3.0 NEO )
Vendor name: INTEL
Driver age: UNKNOWN
Bandwidth: 25 GB / s
Compute score: 223.702
Device name string: Intel(R) UHD Graphics
Device vendor string: Intel(R) Corporation
Platform name string: Intel(R) OpenCL HD Graphics
Platform vendor string: Intel(R) Corporation
End platform OpenCL
{2476 ms}
Exit code kExitNormal
End sniffer 2023-08-20 03:32:22
[kStatusNormal, kExitNormal]
[2610 ms]
Finish RunAllAPIs
[7842 ms]
Start GetSnifferResult
[7842 ms]
Finish GetSnifferResult
======= GPU
License Type: Subscription
Serial number: 96040014154863949572
GUIDBucket:
Composite Core GPU (comp_core_gpu): on
Composite Core Threads (MultithreadedCompositing): on
Composite Core UI (comp_core_ui): off
Composite Core Feature Prefs (CompCoreFeaturePrefs): off
Application folder: C:\Program Files\Adobe\Adobe Photoshop 2023\
Temporary file path: C:\Users\krury\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 1.82T, 1.15T free
Required Plugins folder: C:\Program Files\Adobe\Adobe Photoshop 2023\Required\Plug-ins\
Primary Plugins folder: C:\Program Files\Adobe\Adobe Photoshop 2023\Plug-ins\
Installed components:
ACE.dll ACE 2023/04/13-10:44:44 79.e061fb0 79.e061fb0
act_tracing.dll Copyright (c) 2021 Adobe. All Rights Reserved 1.0.58
AdobeLinguistic.dll Adobe Linguisitc Library dfba77e
AdobeOwl.dll Adobe Owl 5.5.0
AdobePDFL.dll PDFL 2023/01/28-17:08:16 79.4c0bb7e 79.4c0bb7e
AdobePIP.dll Adobe Product Improvement Program 8.2.0.16
AdobeSVGAGM.dll AdobeSVGAGM 79.8567dec 79.8567dec
AdobeXMP.dll Adobe XMP Core 2023/03/23-08:56:37 79.a8d4753 79.a8d4753
AdobeXMPFiles.dll Adobe XMP Files 2023/03/23-08:56:37 79.a8d4753 79.a8d4753
AdobeXMPScript.dll Adobe XMP Script 2023/03/23-08:56:37 79.a8d4753 79.a8d4753
AGM.dll AGM 2023/04/13-10:44:44 79.e061fb0 79.e061fb0
AID.dll AID DLL 1.0.0.58
AIDE.dll AIDE 2023/04/04-19:10:45 79.8b163e2 79.8b163e2
aifm.dll AIFM 1.0 23.68434
AILib.dll Adobe Illustrator 2023 27.1.0
aiport.dll AIPort 1.0 23.68434
ARE.dll ARE 2023/04/13-10:44:44 79.e061fb0 79.e061fb0
AXE8SharedExpat.dll AXE8SharedExpat 2022/12/13-13:20:11 79.002995e 79.002995e
AXEDOMCore.dll AXEDOMCore 2022/12/13-13:20:11 79.002995e 79.002995e
BIB.dll BIB 2023/04/13-10:44:44 79.e061fb0 79.e061fb0
BIBUtils.dll BIBUtils 2023/04/13-10:44:44 79.e061fb0 79.e061fb0
boost_chrono.dll photoshopdva 22.0.0
boost_date_time.dll photoshopdva 22.0.0
boost_filesystem.dll photoshopdva 22.0.0
boost_regex.dll photoshopdva 22.0.0
boost_system.dll photoshopdva 22.0.0
boost_threads.dll photoshopdva 22.0.0
CoolType.dll CoolType 2023/04/13-10:44:44 79.e061fb0 79.e061fb0
CRClient.dll Adobe Crash Reporter Client DLL 12.3.0.202306131643_44f1cd7
DirectML.dll DirectML Redistributable Library 1.10.1+230125-1155.1.dml-1.10.177341d
dnssd.dll Bonjour 3,0,0,2
dvaaccelerate.dll photoshopdva 22.0.0
dvaappsupport.dll photoshopdva 22.0.0
dvaaudiodevice.dll photoshopdva 22.0.0
dvaaudiodsp.dll photoshopdva 22.0.0
dvacore.dll photoshopdva 22.0.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 22.0.0
dvamediatypes.dll photoshopdva 22.0.0
dvametadata.dll photoshopdva 22.0.0
dvametadataapi.dll photoshopdva 22.0.0
dvametadataUI.dll photoshopdva 22.0.0
dvanet.dll photoshopdva 22.0.0
dvaplayer.dll photoshopdva 22.0.0
dvascripting.dll photoshopdva 22.0.0
dvatransport.dll photoshopdva 22.0.0
dvaui.dll photoshopdva 22.0.0
dvavulcansupport.dll photoshopdva 22.0.0
dynamic-torqnative.dll Unified Extensibility Platform uxp-7.1.0-11-16f02e5
dynamiclink.dll photoshopdva 22.0.0
ExtendScript.dll ExtendScript 2022/08/18-12:50:45 82.4 82.4
filterport.dll FilterPort 1.1 O
icucnv71.dll International Components for Unicode Build 14.0.04ee3a5
icuin71.dll International Components for Unicode Build 14.0.04ee3a5
icuuc71.dll International Components for Unicode Build 14.0.04ee3a5
ippcc.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippcck0.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippccl9.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippccy8.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippcore.dll core. Intel(R) Integrated Performance Primitives. Core Library. 2021.6 (r0xbffe3c5b)
ippcv.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippcvk0.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippcvl9.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippcvy8.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippi.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ippik0.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ippil9.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ippiy8.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ipps.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippsk0.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippsl9.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippsy8.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippvm.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
ippvmk0.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
ippvml9.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
ippvmy8.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
JP2KLib.dll JP2KLib 2023/03/10-17:55:06 79.6dcde51 79.6dcde51
libeay32.dll The OpenSSL Toolkit 1.0.2zf
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(R) C/C++/Fortran Compiler Mainline
libzip.dll photoshopdva 22.0.0
LogSession.dll LogSession 8.2.0.16
mediacoreif.dll photoshopdva 22.0.0
Microsoft.AI.MachineLearning.dll Microsoft® Windows® Operating System 1.14.20230410.1.429e1e3
mkl_avx2.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_avx512.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_core.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_def.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_mc3.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_sequential.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_avx2.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_avx512.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_def.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_mc3.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
MPS.dll MPS 2023/03/30-19:06:20 79.fb3b9df 79.fb3b9df
onnxruntime.dll Microsoft® Windows® Operating System 1.14.20230410.1.429e1e3
opencv_world452.dll OpenCV library 4.5.2
pdfport.dll PDFPort 2020/11/19-11:34:27 79.625377 79.625377
Plugin.dll Adobe Photoshop 2023 24.7
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 11.5.2
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 11.5.2.130
PSCloud.dll 1.0.0.1
PSRes.dll Adobe Photoshop 2023 24.7
PSViews.dll Adobe Photoshop 2023 24.7
ScCore.dll ScCore 2022/08/18-12:50:45 82.4 82.4
ssleay32.dll The OpenSSL Toolkit 1.0.2zf
SVGRE.dll SVGRE 79.e41acba 79.e41acba
svml_dispmd.dll Intel(R) C/C++/Fortran Compiler Mainline
VulcanControl.dll Vulcan Application Control Library 7.2.0.34
VulcanMessage5.dll Vulcan Message Library 7.2.0.34
WinRTSupport.dll Adobe Photoshop Windows RT Support 1.0.1.0
WRServices.dll WRServices Build 17.5.1.73e2151 17.5.1.73e2151
UPIC 2.6.0
Required plugins:
Accented Edges 24.7 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 24.7 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 24.7 - from the file “Filter Gallery.8bf”
Average 24.7 - from the file “Average.8bf”
Bas Relief 24.7 - from the file “Filter Gallery.8bf”
BMP 24.7 - from the file “Standard MultiPlugin.8bf”
Camera Raw 15.5 - from the file “Camera Raw.8bi”
Camera Raw Filter 15.5 - from the file “Camera Raw.8bi”
Chalk && Charcoal 24.7 - from the file “Filter Gallery.8bf”
Chrome 24.7 - from the file “Filter Gallery.8bf”
Cineon 24.7 - from the file “Cineon.8bi”
Clouds 24.7 - from the file “Clouds.8bf”
Color Halftone 24.7 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 24.7 - from the file “Filter Gallery.8bf”
Conté Crayon 24.7 - from the file “Filter Gallery.8bf”
Craquelure 24.7 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 24.7 - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 24.7 - from the file “Standard MultiPlugin.8bf”
Crosshatch 24.7 - from the file “Filter Gallery.8bf”
Crystallize 24.7 - from the file “Standard MultiPlugin.8bf”
Cutout 24.7 - from the file “Filter Gallery.8bf”
Dark Strokes 24.7 - from the file “Filter Gallery.8bf”
De-Interlace 24.7 - from the file “Standard MultiPlugin.8bf”
Dicom 24.7 - from the file “Dicom.8bi”
Difference Clouds 24.7 - from the file “Clouds.8bf”
Diffuse Glow 24.7 - from the file “Filter Gallery.8bf”
Displace 24.7 - from the file “Standard MultiPlugin.8bf”
Dry Brush 24.7 - from the file “Filter Gallery.8bf”
Entropy 24.7 - from the file “statistics.8ba”
Export Color Lookup Tables 24.7 - from the file “Export3DLUT.8be”
Extrude 24.7 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 24.7 - from the file “FastCore.8bx”
Fibers 24.7 - from the file “Standard MultiPlugin.8bf”
Film Grain 24.7 - from the file “Filter Gallery.8bf”
Filter Gallery 24.7 - from the file “Filter Gallery.8bf”
Fresco 24.7 - from the file “Filter Gallery.8bf”
Glass 24.7 - from the file “Filter Gallery.8bf”
Glowing Edges 24.7 - from the file “Filter Gallery.8bf”
Graphic Pen 24.7 - from the file “Filter Gallery.8bf”
Halftone Pattern 24.7 - from the file “Filter Gallery.8bf”
Halide Bottlenecks 24.7 - from the file “HalideBottlenecks.8bx”
HDRMergeUI 24.7 - from the file “HDRMergeUI.8bf”
HSB/HSL 24.7 - from the file “Standard MultiPlugin.8bf”
IFF Format 24.7 - from the file “Standard MultiPlugin.8bf”
Ink Outlines 24.7 - from the file “Filter Gallery.8bf”
JPEG 2000 24.7 - from the file “JPEG2000.8bi”
Kurtosis 24.7 - from the file “statistics.8ba”
Lens Blur 24.7 - from the file “Lens Blur.8bf”
Lens Correction 24.7 - from the file “Lens Correction.8bf”
Lens Flare 24.7 - from the file “Standard MultiPlugin.8bf”
Liquify 24.7 - from the file “Liquify.8bf”
Luminar Neo 17.0 - from the file “LuminarNeo.8bf”
LUT Mixer NO VERSION - from the file “LUT Mixer.8bf”
Matlab Operation 24.7 - from the file “ChannelPort.8bf”
Maximum 24.7 - from the file “statistics.8ba”
Mean 24.7 - from the file “statistics.8ba”
Measurement Core 24.7 - from the file “MeasurementCore.8me”
Median 24.7 - from the file “statistics.8ba”
Mezzotint 24.7 - from the file “Standard MultiPlugin.8bf”
Minimum 24.7 - from the file “statistics.8ba”
MMXCore Routines 24.7 - from the file “MMXCore.8bx”
Mosaic Tiles 24.7 - from the file “Filter Gallery.8bf”
Multiprocessor Support 24.7 - from the file “MultiProcessor Support.8bx”
Neon Glow 24.7 - from the file “Filter Gallery.8bf”
Note Paper 24.7 - from the file “Filter Gallery.8bf”
NTSC Colors 24.7 - from the file “NTSC Colors.8bf”
Ocean Ripple 24.7 - from the file “Filter Gallery.8bf”
OpenEXR 24.7 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 24.7 - from the file “Filter Gallery.8bf”
Palette Knife 24.7 - from the file “Filter Gallery.8bf”
Patchwork 24.7 - from the file “Filter Gallery.8bf”
Paths to Illustrator 24.7 - from the file “Standard MultiPlugin.8bf”
PCX 24.7 - from the file “PCX.8bi”
Photocopy 24.7 - from the file “Filter Gallery.8bf”
Picture Package Filter 24.7 - from the file “ChannelPort.8bf”
Pinch 24.7 - from the file “Standard MultiPlugin.8bf”
Pixar 24.7 - from the file “Pixar.8bi”
Plaster 24.7 - from the file “Filter Gallery.8bf”
Plastic Wrap 24.7 - from the file “Filter Gallery.8bf”
Pointillize 24.7 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 24.7 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 24.7 - from the file “PBM.8bi”
Poster Edges 24.7 - from the file “Filter Gallery.8bf”
Radial Blur 24.7 - from the file “Standard MultiPlugin.8bf”
Radiance 24.7 - from the file “Radiance.8bi”
Range 24.7 - from the file “statistics.8ba”
Render Color Lookup Grid 24.7 - from the file “Export3DLUT.8be”
Reticulation 24.7 - from the file “Filter Gallery.8bf”
Retouch4me Heal 1.0 - from the file “Retouch4me Heal.8bf”
Ripple 24.7 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 24.7 - from the file “Filter Gallery.8bf”
Save for Web 24.7 - from the file “Save for Web.8be”
ScriptingSupport 24.7 - from the file “ScriptingSupport.8li”
Shear 24.7 - from the file “Standard MultiPlugin.8bf”
Skewness 24.7 - from the file “statistics.8ba”
Smart Blur 24.7 - from the file “Standard MultiPlugin.8bf”
Smudge Stick 24.7 - from the file “Filter Gallery.8bf”
Solarize 24.7 - from the file “Solarize.8bf”
SP Substance Suite NO VERSION - from the file “MaterialSuite.8li”
Spatter 24.7 - from the file “Filter Gallery.8bf”
Spherize 24.7 - from the file “Standard MultiPlugin.8bf”
Sponge 24.7 - from the file “Filter Gallery.8bf”
Sprayed Strokes 24.7 - from the file “Filter Gallery.8bf”
Stained Glass 24.7 - from the file “Filter Gallery.8bf”
Stamp 24.7 - from the file “Filter Gallery.8bf”
Standard Deviation 24.7 - from the file “statistics.8ba”
Substance NO VERSION - from the file “MaterialFilter.8bf”
Sumi-e 24.7 - from the file “Filter Gallery.8bf”
Summation 24.7 - from the file “statistics.8ba”
Targa 24.7 - from the file “Standard MultiPlugin.8bf”
Texturizer 24.7 - from the file “Filter Gallery.8bf”
Tiles 24.7 - from the file “Standard MultiPlugin.8bf”
Topaz Photo AI NO VERSION - from the file “TopazPhotoAI.8bf”
Torn Edges 24.7 - from the file “Filter Gallery.8bf”
Twirl 24.7 - from the file “Standard MultiPlugin.8bf”
Underpainting 24.7 - from the file “Filter Gallery.8bf”
Vanishing Point 24.7 - from the file “VanishingPoint.8bf”
Variance 24.7 - from the file “statistics.8ba”
Water Paper 24.7 - from the file “Filter Gallery.8bf”
Watercolor 24.7 - from the file “Filter Gallery.8bf”
Wave 24.7 - from the file “Standard MultiPlugin.8bf”
WIA Support 24.7 - from the file “WIASupport.8li”
Wind 24.7 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 24.7 - from the file “WBMP.8bi”
ZigZag 24.7 - from the file “Standard MultiPlugin.8bf”
Optional and third party plugins: NONE
Duplicate and Disabled plugins:
Topaz Photo AI NO VERSION - from the file “C:\Program Files\Adobe\Adobe Photoshop 2023\Plug-ins\TopazPhotoAI.8bf”
Plugins that failed to load: NONE
Unified Extensibility Platform - Extensions:
Home Screen (Loaded) 6.7.0.42 - from the file "Required Folder"
CDO: 1.141.0
CmdN: 1.18.8
CDP: 1.165.0
Projects: 1.7.0
Loaded at: 177 ms - launch time impact: 32 ms
ccx-timeline (Prepared) 3.1.10.0 - from the file "Required Folder"
CCX Commenting UXP Webview (Loaded) 27.3.1.0 - from the file "Required Folder"
Loaded at: 17937 ms - launch time impact: 0 ms
CCX Sharesheet UXP (Prepared) 24.10.0.0 - from the file "Required Folder"
Photoshop Cloud Value Dialog (Loaded) 1.0.1.0 - from the file "Required Folder"
Loaded at: 184 ms - launch time impact: 0 ms
Share Panel (Loaded) 1.0.6.0 - from the file "Required Folder"
Loaded at: 190 ms - launch time impact: 0 ms
Content Credentials (Loaded) 0.37.3.0 - from the file "Required Folder"
Loaded at: 14137 ms - launch time impact: 2 ms
CC Libraries Panel (Prepared) 3.24.22.0 - from the file "C:\Program Files\Common Files\Adobe/CEP/Extensions\CC_LIBRARIES_PANEL_EXTENSION_3_24_22\"
CAPTURE: 2.0.41 STOCK: 4.0.2
Substance 3D (Loaded) 0.1.6.0 - from the file "Required Folder"
Loaded at: 17943 ms - launch time impact: 0 ms
Photoshop Adjustments Panel (Loaded) 1.29.13.0 - from the file "Required Folder"
Loaded at: 17950 ms - launch time impact: 3 ms
Photoshop UXP Export-As (Loaded) 5.8.23.0 - from the file "Required Folder"
Loaded at: 7369911 ms - launch time impact: 0 ms
Photoshop Facepile (Loaded) 1.2.1.0 - from the file "Required Folder"
Loaded at: 17955 ms - launch time impact: 0 ms
Photoshop In App Messaging (Loaded) 4.2.1.0 - from the file "Required Folder"
Loaded at: 17961 ms - launch time impact: 2 ms
Photoshop Selection Feedback (Prepared) 0.5.0.0 - from the file "Required Folder"
Plugins Panel (Prepared) 1.4.3.0 - from the file "Required Folder"
IC popup message (Loaded) 1.0.0.0
Loaded at: 16828 ms - launch time impact: 0 ms
Multilayer Protection (Loaded) 1.0.0.0
Loaded at: 16833 ms - launch time impact: 0 ms
Discover Panel (Loaded) 2306.76.0.24 - from the file "Required Folder"
Loaded at: 17970 ms - launch time impact: 0 ms
Neural Filters (Registered) 1.15.0.95 - from the file "Required Folder"
Scan time: 0 ms - entries: 24
Extensions:
Libraries 1.0.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_24_22\index.html”
com.adobe.stock.panel.licensing-embedded 1.0.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_24_22\extensions\stock-panel-licensing\index.html”
com.adobe.capture.extension 2.0.41 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_24_22\extensions\capture\capture.html”
FX Box 1.1.0 - from the file “C:\Users\krury\AppData\Roaming\Adobe\CEP\extensions\fx_box.extension\index.html”
Export As 4.8.15 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2023\Required\CEP\extensions\com.adobe.photoshop.crema\index.html”
com.adobe.cclibraries.manager 1.0.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_24_22\manager.html”
Installed TWAIN devices: NONE
