flickering and layout of the rules in external display (LG40WP95C) Macbook Pro M1 MAX
  • January 28, 2023
  • 243 views
When I connect the Macbook to an external monitor (with thunderbolt), when I enlarge the photoshop window, the rulers get inside the image (attached screenshot) and it flickers when I move the mouse cursor, I insert guides and other functions. For that reason I can't work with photoshop with a big window. This only happens with photoshop, it doesn't happen with Premiere or After Effects.
Macbook Pro M1 MAX
MacOS Ventura 13.1
External display (LG40WP95C)
Photoshop 24.1.0
Updating to 24.1.1 has fixed the issue. Thanks Cory
CShubert
Hi @juanv86246728 thank you for the post. Have you tried updating to Ps 24.1.1, does the issue persist?
Go to Preferences > Technology Previews... and check "Disable Native Canvas" - then restart Photoshop. Does the problem still occur?
Thank you,
Cory
