How to draw around the circle using brush tool (without using pen tool and stroke option)?
  • July 10, 2022
  • 1156 views
Hello,is there a option for drawing around a circle made with ellipse tool without stroke on it?
I mean,i want to make that stroke option manually by drawing with Brush tool.And i want it to not go inside the circle and fill it.Thanks.
c.pfaffenbichler
To stroke a Path with a Brush there’s »Stroke path with brush«,
to hide an area while painting there are Vector Masks and Layer Masks for example,
but I am not quite sure what you are actually trying to achieve … please post a clear description and sketches to illustrate your point.
drawiuAuthor
I wanted to achieve this drawing by drawing manually with mouse,not with directly stroke option.I mean i want to create an ellipse and use it like a circle-shaped ruler and draw across that ruler.
Abambo
quote
By @drawiu
And what would be different to what @c.pfaffenbichler showed you, as his solution is essentially what I understand what you want to do, except that you do not need to move your mouse around?
