How to merge layers and their edited parts
  • May 14, 2020
  • 585 views
I did some frequency separation on the arms and face and put them in a group
Beneath the group are my layers for the glowing glasses and the background.
How do I combine the two? When I merge them, it doesn't work.
c.pfaffenbichler
Why don’t you move the Adjustment Layers atop?
The adjustment layers seem to work but the layer 3 won't show the skin adjustments I made in group 1.
Or put another way the skin adjustments won't show the glasses layer when I put that on top. Very annoying.
I get the feeling it is simple but I am unfamiliar with photo shop
c.pfaffenbichler
I don’t understand your problem.
Group 1 seems to contain Layers covering the whole Canvas so naturally they cover what’s below them.
