Jp_508
How to Speed Up Moving Text Box & Images
  • July 1, 2023
  • 652 views
I work with my wife who is a realtor and created custom PSD templates for real estate postcards. The cards have a few listing images with test describing the listing. If I need to select an image or text (Ctrl-T) then use the up & down arrows to move into place the image/text moves very slowly. At a snails pace, is there a way to speed this up by using the up/down arrows? I was able to do this in past versions and it was pretty quick. I believe I had to hold down Alt, Ctrl, or Shift at the same time, it was one of those but doesn't do it any more. Is this still possible? Thanks for reading.
Semaphoric
The arrow keys nudge by one pixel, and Shift+Arrow keys will nudge ten pixels.
Also, Control+T is the shortcut for Free Transform. for just moving things around, the Move tool (V) is a lot more direct.
Jp_508
Jp_508Author
Yep that did it. When working with images I'm always selecting Ctrl-T so
inadvertently do it again with text. Never occurred to me to select the
Move tool. Thanks for the help.
