What was the help that was provided? Uninstall and reinstall; same as OS restore ... Formatt the machine then install a fresh OS with the Apps. Virtual Machines, restore the VM to its best state ...etc.
I wish that you provided me with an executable file that solve the language problem. A file that lets you select the language you want to use then install the required files and setup the setting for this language. Files that are required by the operating system such as changing the ASCII to Unicode, Language support packages, Keyboard layout, input methods, fonts,…etc and the settings required by the App. I think Adobe development team can make such a tool.
Sign up
To post, reply, or follow discussions, please sign in with your Adobe ID.
Sign inSign in to Adobe Community
Sign inEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
