No options after right CLick
  • January 29, 2018
  • 10455 views
Hello, so I want to edit a picture, but the thing is:
I open up the picture document. It´s there. I convert it into a layer.
But when I click with the right mouse button on the picture there won´t be any options to edit the picture (see screenshot)
Why?
Correct answer c.pfaffenbichler
Furn example turning 180°.
You do not seem to have initiated a transformation yet, you just have the Move Tool set to »Show Transform Controls«.
Invoke the Transformation (cmd-T) … edit: ctrl-T on Windows, I guess.
Barb Binder
c.pfaffenbichler is exactly right. Because you activated Show Transform Controls, it looks like you are in a transform box but you aren't. You can see the transform handles, but you have not yet initiated Edit > Free Transform.
See the difference after Edit > Free Transform?
~Barb
c.pfaffenbichler
What kind of edits do you expect to be listed in that dialog? (edited)
What kind of editing do you want to perform on the image?
I know where to find this options but normally I should be able to find them by right clicking on the picture.
c.pfaffenbichler
c.pfaffenbichlerCommunity ExpertCorrect answer
