Oil Paint filter won't work ... tells me Drivers need updating
Good day ... Went a to a new MacBook Pro not long ago ... info below. Loaded up the Adobe applications
that I have been using successfully on previously MacBook Pros as well as MacPros. After updating to
Photoshop 19.1.16 the application started acting buggy. This in terms of speed being much slower in various
ways and now the current issue is that I'm unable to use filters like oil paint as it returns a message saying
the Intel Iris Pro video needs to be updated. The OS is as current as offered for the laptop as are the drivers
and I sent a considerable amount of time trying to find a solution to this last night without any luck.
What am I missing here?
Thanks for your time and assistance.
Ira Zoot
| Computer and OS | Header 2 |
Model Name: MacBook Pro Model Identifier: MacBookPro11,4 Processor Name: Intel Core i7 Processor Speed: 2.8 GHz Number of Processors: 1 Total Number of Cores: 4 L2 Cache (per Core): 256 KB L3 Cache: 6 MB Memory: 16 GB Boot ROM Version: MBP114.0184.B00 SMC Version (system): 2.29f24 Serial Number (system): C02WT1C3G8WL Hardware UUID: D247A35B-49DD-5A44-B368-A900B0151532 | |
Intel Iris Pro: Chipset Model: Intel Iris Pro Type: GPU Bus: Built-In VRAM (Dynamic, Max): 1536 MB Vendor: Intel Device ID: 0x0d26 Revision ID: 0x0008 Metal: Supported, feature set macOS GPUFamily1 v3 Displays: Color LCD: Display Type: Built-In Retina LCD Resolution: 2880 x 1800 Retina Framebuffer Depth: 24-Bit Color (ARGB8888) Main Display: Yes Mirror: Off Online: Yes Rotation: Supported Automatically Adjust Brightness: No | |
