photoshop 24.3.0 gradient line starting point problem
  • March 31, 2023
  • 5250 views
Hi;
I'm using photoshop cc 24.3.0 on my win 10 pc.
Hre is my problem, I used to draw gradient lines, whereever I want beyond the edges of the canvas (a photograph) but now I can't do this, it only allows me to draw the line from the edges of the photo, not below the canvas anymore.
Correct answer davescm
I've just checked to see that I'm using the updated driver for my nvidia gt730 driver and when "use graphics processor" is checked, then the blinking screen problem occurs. If it is unchecked , then the image opens without any problems but gradient tool's line is not visible until it is on the image..
Rather than disabling your GPU, have you tried leaving that enabled and going to Preferences Technology Previews and checking Deactivate Native Canvas. That should stop the flashing screen without disabling all GPU functionality.
Dave
ClaudiaR99
Hello @darto1976 , thanks for reporting this issue. I'd like to ask a bit more about what is the gradient line that it's shown in the image.
When drawing a gradient the line has a blue dot and a thin line as you can see in the gif attached.
I know that there should be a blue dot but mine has a cursor instead. I can't do what you did there.
davescm
davescmCommunity ExpertCorrect answer
Dave
Ranjisha Sengupta
Hi @darto1976
Thanks for reaching out.
You are correct that the lines can be pulled beyond to adjust the gradient flow. Strangely, it's not happening on your end.
What type of document are you working with? Can you please share a screenshot of the scene with the gradient tool selected?
You may try resetting Photoshop preferences back to defaults and check if that helps. Here's the article for the steps: https://adobe.ly/3ceal5t.
Also, back up the existing Photoshop preferences if you have any custom brushes, action, and workspace: https://adobe.ly/2vNz6FG
Let us know how it goes.
Best,
Ranjisha
Hi Ranjisha;
thx for your reply. I have tried resetting photoshop preferences both ways:
by using the photoshop edit->preferences dialoge and by manually removing preferences files from the folder (which is described on the link you sent to me) but nothing's changed, still not working,  the grad line can not be pulled beyond.
here is a screenshot:
c.pfaffenbichler
What is the Photoshop > Preferences > Tools > Overscroll-setting?
