  • October 31, 2007
  • 680 replies
  • 62289 views
Pete
    December 3, 2007
    I'm not sure, but it sounds like you're talking about converting between profiles, or viewing within colour managed applications. I am talking about sRGB images being displayed in non-colour managed environments on monitors that display wider gamut than sRGB. As far as I know, the SFW preview window is showing a non-colour managed preview.
    As you know, a colour value - say r255 b12 g25 - is one colour in sRGB and a similar but different colour in Adobe RGB or other different colour spaces. So a colour managed environment recognizes how that colour value should appear, but without colour management, that colour gets mapped to the display profile. Thus, an sRGB image viewed on a wide-gamut monitor without colour management will not appear correctly. The wide-gamut monitor may be perfectly calibrated, but if there's no colour management, it will not know the correct way to display the image.
    Does this sound right?
    yes
    If the image color space has a smaller color gamut then the monitor, there "should be" no perceptual defects between what color space the image is in and what the monitor is showing you.
    December 3, 2007
    Ok forget Adobe RGB. What I meant really was that there are some monitors that are capable of displaying a wider gamut than sRGB, and when properly calibrated and profiled MAY still use a wider gamut than sRGB. Is this not true?
    People who use SFW deserve to be confused. Color manglement at its best, brought to you by the good friends at Adobe for lack of proper implementation and real market research by people who know what the F they are doing...
    nice.
    Ramón G Castañeda
    > An Adobe RGB monitor, accurately calibrated and profiled, will be using the Adobe RGB colour space, right?
    Only if you don't have a clue as to how to calibrate and profile a monitor. Adobe RGB is a device-independent color space; your calibrated and profiled monitor will NOT be using Adobe RGB at all but its own device-dependent color profile. That's the whole point of profiling!
    You clearly do not understand color calibration and profiling, nor color management at all.
    >I'm talking about an image that has already been converted to sRGB (or has always been sRGB) before launching SFW.
    If all of the conditions I mentioned earlier are met, you should NOT see a color shift in that scenario.
    If you insist on working with untagged images and subjecting them to a tortured workflow, all bets are off.
    Really, Raven, at this point I'm out of here. This is one of the most preposterous threads I've read here.
    December 3, 2007
    An Adobe RGB monitor, accurately calibrated and profiled, will be using the Adobe RGB colour space, right? And an sRGB intended image, without colour management, will be incorrectly mapped to that monitor's colour space, right? Would that not result in an over saturated image in SFW and any other non-colour managed environment?
    Not talking about converting an Adobe RGB image to sRGB...I understand that there may be a colour shift in that conversion process. I'm talking about an image that has already been converted to sRGB (or has always been sRGB) before launching SFW.
    Ramón G Castañeda
    > Not if you know what you are doing
    and within the limitations of the narrower sRGB color space, of course. If your original image has colors outside the gamut of sRGB, then yes, there will be a color shift REGARDLESS of the monitor you use. A better monitor will allow you to see the color compression or clipping better, but just because you have a poor monitor does not mean that there won't be a color shift in that scenario, just that you can't see it.
    Use soft proofing to correct your colors and saturation BEFORE Saving For Web.
    Ramón G Castañeda
    Not if you know what you are doing.
    December 3, 2007
    The Eizo ColorEdge CG221 monitor is marketed as an Adobe RGB monitor. Are you saying that that monitor, accurately calibrated and profiled will not result in a colour shift?
    Ramón G Castañeda
    >3. Use of a monitor which has a gamut that differs from sRGB
    I'm not sure I agree with 3 as stated at all. An accurately calibrated and correctly profiled monitor should not cause a color shift. It will show you differences in luminance (apparent saturation discrepancies) based on gamma differences (e.g. 2.2 v. 1.8). However, further discussion is futile.
    There can be other causes for a color shift during color conversions, e.g. choosing the wrong color engine (Apple instead of ACE), rendering intent, etc.
