  • October 31, 2007
  • 680 replies
  • 62257 views
Pete
    November 23, 2007
    While Ramon relaxes in his cozy den of infinite superiority, I'll restate the following in hopes that I might receive some interesting comments or feedback:
    SFW is showing me the difference between sRGB and my monitor profile. (This is confirmed in tests using different monitor profiles.)
    This Dell monitor requires a significant shift away from sRGB in order to display accurately. (Again, using the sRGB monitor profile here produces horrible colours and overly bright shadows and is not an option.)
    That a monitor profile differing from sRGB is not in and of itself a bad thing.
    Therefore, seeing a colour shift in SFW does not necessarily mean I have a bad profile.
    A major point I'm making here is that SFW behaviour is probably not the best indication of a good or bad monitor profile. I have revised my understanding of the way that SFW works.
    Ramón G Castañeda
    Double sigh!
    November 23, 2007
    <sigh>
    Opinions not answers!
    Ramón G Castañeda
    Raven,
    At this rate, you'll get up to 1,000 posts in a hurry.
    You have been given all the answers. Any further discussion with you is futile.
    November 22, 2007
    You've got to be kidding me Ramon. Why don't you drop the attitude. When you say "Sigh..." did you mean to say "Here's a possible reason your monitor could be very far off and still appear to look ok to you..." or did you mean to say "What an idiot, he thinks his monitor is fine!"
    Hey thanks for the help Ramon, yeah very helpful.
    Ramón G Castañeda
    >It's very hard for me to believe that my monitor profile is sooo far off
    Sigh
    November 22, 2007
    It's very hard for me to believe that my monitor profile is sooo far off that it would account for the dramatic colour shift I see in SFW. It may be that my monitor profile is not exactly perfectly accurate, but I have a, let's call it a "real world" tolerance for small differences. That is to say, when using my test image as a reference, I am seeing about the right amount of detail in the shadows and highlights, and the colours are pretty close and not obviously green tinted or anything. Perhaps I have a higher tolerance than some others here, but I assert that my monitor profile is not horribly wrong.
    Here's what I now believe:
    I think that if I was to use one of those recommended calibrators and achieved calibration perfection that I would still see a shift in SFW. (I don't think we've heard from anyone who has the same Dell monitor that has calibrated it and not had the SFW "problem".) There's no way for me to know because that's not going to happen...it's not a priority in this company, not when we are getting predictable results from our print jobs already.
    I am sorry for the angry tone I have taken, I prefer not to stoop to that level. Obviously this can be a very frustrating subject and I felt I was being insulted. Thanks Peter for trying to go in to more detail for me.
    Ramón G Castañeda
    >I will admit that I have not gone to the extreme lengths you've described.
    Those are b>far from "extreme lengths". They are the minimum norms.
    What Buko said: you have a bad monitor profile a crappy calibrator and a cheap monitor.
