  • October 31, 2007
  • 680 replies
  • 62091 views
Pete
    November 5, 2007
    "I guess I'll try to find answers somewhere else."
    I think all the answers are here in this thread. You just have to read through them and try the different ways of saving out to Jpeg...
    This is what I do:
    Open a .jpg from the existing site (which was saved prior to CS3). Copy, paste from new file onto this jpg. Flatten image and Save (sometimes you get a jpg quality dialog box, sometime not.
    This works for me.
    November 5, 2007
    Also keep in mind that Adobe RGB is a larger color space than sRGB and depending on the image a conversion to sRGB from aRGB with clip the space causing color to shift a little. Just like converting from RGB to CMYK although not as drastic.
    November 5, 2007
    Ballard's site is a great starting point.
    November 5, 2007
    So much for the help and patience of those trying to explain this stuff. It does matter Ramon, but I guess I'll try to find answers somewhere else.
    So Ramon and MO let us in so that we can roll around the floor also!
    Ramón G Castañeda
    Larry,
    Yes, I should have added "for Tiger".
    Ramon - Safari 3.0.4 is now the current non-beta version. I'm running it with 10.5. I haven't read anything as to whether it's a good idea or not to run it with 10.4.10.
    Ramón G Castañeda
    >So I still don't get what you're trying to say
    Forget it, then. It doesn't matter.
    November 4, 2007
    Ramon...I appreciate your effort to explain, but there is still a lack of understanding here. TO try to reiterate: I created a crap monitor profile using the Display Preferences calibration tool. Dark. Orange. I'm not talking about tagging an image with a dark and orange biased colour profile, I'm talking about a monitor colour profile as chosen in the Display Preferences panel. How can you say Photoshop will use it and Word will not, when I choose this crap profile, everything that is displayed is affected by it, including menu bars, preference boxes, websites...I'm talking about everything on the screen. You know when you're messing around with the gamma setting and stuff you are seeing the whole screen changing. I see this as a global display preference, so that if the monitor display is accurate globally, then my eye can trust what photoshop shows me when it uses different tagged image profiles for different purposes.
    So I still don't get what you're trying to say. This is a very challenging subject to explain apparently because nobody here who SEEMS to know what is going on has been able to clearly explain.
    You make a distinction between Calibrating and Profiling a monitor. When I calibrate using SpyderPro, is it not saving a monitor profile (white balance, gamma settings, etc.) which shows up in the list of colour profiles in the Display Preferences panel? For the system to use globally for the display as a whole? Perhaps you could explain the distinction between calibrating and profiling. (I figure calibration is the process, and the profile is the end result, display preference file, or whatever.)
    Again I appreciate the help and patience of those trying to explain this stuff.
